It is currently Thu Aug 06, 2026 5:58 am
 Post subject: Few more odds n ends
PostPosted: Tue May 03, 2022 5:40 pm
Not sure of class for these boards.
 Post subject: Re: Few more odds n ends
PostPosted: Sat May 07, 2022 6:33 pm
1) High peripheral at minimum, remove the bracket.
2) Low peripheral
3) Clean GFC
4) I'm leaning high telco if you remove the bracket
5) Not sure how the display affects this board
PostPosted: Mon May 09, 2022 1:26 pm
What class would 5 fall into with the screen.
PostPosted: Mon May 09, 2022 3:29 pm
Certain displays can add value, LostinLodos has a better understanding of that and has posted things in the past to indicate as much.
With or without the display I'm stuck between high and low peripheral. The board itself seems lower value but has several chips that might push it high and the display may or may not help it over the edge. But the board could be high on its own and the display brings it down or it's just low regardless.
That's where I'm at and why I didn't offer a grade.
PostPosted: Tue May 10, 2022 9:53 am
I appreciate the info. I chips are what threw me off to check class. If it did not have those would have put in mid grade. Thanks again.
