 Post subject: Diamond Computer Set# 10
PostPosted: Wed May 04, 2022 10:09 am
With 300+ Laptops and Chromebooks on the horizon, I am looking to clear my area ASAP.
C.
File comment: Set 10 Front
File comment: Set 10 Back
PostPosted: Thu May 05, 2022 2:29 pm
These look like all in one motherboards, but B is missing the part with the CPU socket. I can't remember which category all in ones fall into but I'll try to search for a past post.
PostPosted: Thu May 05, 2022 4:53 pm
Diamond,
I'm sure I've looked at your posts several times and always think, I'll come back to this when I have more time, cause, unfortunately, I feel a bit overwhelmed looking at all the boards. Hopefully I get some time this weekend unless someone beats me to it.
As for these, I'm not sure I remember where the all in ones go either, I need to figure that out, they're starting to show up more often. Board B though, looks like a docking station board which is typically high peripheral.
PostPosted: Fri May 06, 2022 8:13 am
I didn't think about that, but you are correct. That's why it has all the connectors but no CPU.
PostPosted: Fri May 06, 2022 8:31 am
B is from a dock. High peripheral does sound right to me, but I submit to be sure. A and C are from SFF PC's.
Marked I appreciate you mentioning the delay and look forward to your responses. I can understand getting busy, but was beginning to wonder if I might have BO or a big zit I was not aware of. he heh heh Good thing with the 300+ laptops I have coming up is you will only get one pic per model and I will have my crew sort the rest.
C.
PostPosted: Fri May 06, 2022 11:59 am
I was thinking small form factor, but I typed all in one instead. SFFs are (usually) small socket mother boards.
PostPosted: Fri May 06, 2022 12:40 pm
So if I am reading this right, A and C are Small Socket Green MB's, and B is High-Peripheral? is about what I suspected, but always like to be sure.
C.
PostPosted: Sat May 07, 2022 6:44 pm
... was beginning to wonder if I might have BO or a big zit I was not aware of...
Possibly...hopefully that's not translating through the forum :D
Yes I think you got what ropeman and I bantered back and forth about.
I did my best, hopefully it helps.
PostPosted: Tue May 10, 2022 12:49 pm
Going with the Small Green MB for A & C, High Peripheral for B...and some Oxy for that Zit. I appreciate the efforts over the weekend and helping me clean up my space a bit.
Sorted, Thank You.
C.
PostPosted: Tue May 10, 2022 4:18 pm
. . . was beginning to wonder if I might have BO or a big zit I was not aware of.
This post was a little easier so I chimed in. Those other posts with all manner of tiny strange boards overwhelms me! That's why I still have several boxes of stuff like that in storage.
It would be nice if you could come back with what Boardsort really classified some of these as. Will they let you know what changed category when they receive it?
