 Post subject: Diamond Computer Set# 14
PostPosted: Wed May 04, 2022 10:30 am
With 300+ Laptops and Chromebooks on the horizon, I am looking to clear my area ASAP.
Grid portable computer.
A-looks to have some tasty chips onboard.
D- has a removable daughter board in the lower right of the Front Pic
F-has the Copper Wire removed, include or no?
H-I guess as IC Chips
Are the cables of any value? If so, as what Category?
C.
File comment: Set 14 Front
File comment: Set 14 Back
File comment: Set 14 Cables
PostPosted: Sat May 07, 2022 5:57 pm
A: Gold Cap Chip board
B: Midgrade
C: I want to say low telco; probably on the lower end
D: High Telco boards together or separated; that white shrink wrapped component looks like a battery, remove if so. Out of curiosity, the three grayish chips (???) two with a blue label one an off white, could you get a closer picture maybe at a slight angle? Again just curious no worries if you don't want to.
E: Mid grade
F: Copper windings would be a separate grade dependent on the yard you take it to, could be electric motor or copper shred or copper content or... anyways. I think low peripheral on the board
G: High telco
H: If the plastic or whatever they're on is just plastic you can remove it and the chips are IC chips
PostPosted: Tue May 10, 2022 1:05 pm
A. Would that be "Gold Cap & Gold Edge & CNC boards"?
...and I guess Cables are trash? (Decided to ask given the age.)
Otherwise sorted, Thank You,
C.
PostPosted: Tue May 10, 2022 4:03 pm
Right! The gold cap category has had additional info added to its description. I'm not writing all that out unless I can copy/paste on my computer, often times I'm on my phone.
The cables I managed to skip over completely... Mixed wire I think is how boardsort would take it. I put it in my #3 insulated wire for my local scrap yard.
PostPosted: Tue May 10, 2022 4:06 pm
Yeah, I don't remember if the gold edge & CNC part was ever explained in detail, but personally I think it is three categories of board all grouped into one.
PostPosted: Wed May 11, 2022 8:46 am
Sorted, Thank you.
C.
