It is currently Wed Aug 05, 2026 4:17 pm
 Post subject: Diamond Computer Set 8
PostPosted: Tue Apr 12, 2022 2:49 pm
Looking for classifications as I get started on this project again.
C.
PostPosted: Thu Apr 14, 2022 2:13 pm
Yes, H will have that pesky wire clipped. ;-)
C.
PostPosted: Wed May 04, 2022 10:35 am
Bump, Bump...
C.
PostPosted: Sat May 07, 2022 6:22 pm
A/D/F/G: I think some discussion awhile back was throwing these as connector ends.
B: Low telco
C: Low peripheral at least, possibly high
E: uhm... ¯\_(ツ)_/¯
H: Is that the magnetic power port for an Apple laptop? Think it's midgrade regardless.
PostPosted: Tue May 10, 2022 12:44 pm
Sending C as Low Peripheral. Is a webcam from a laptop...I will likely have a few hundred of similar boards soon to send, so curious how I should sort them.
E. Dunno, is why I sent it. ;-)
H. Yes I believe it may be from a Mac.
Sorted but holding off on C and E for the moment.
C.
PostPosted: Tue May 10, 2022 4:23 pm
I would put all the little questionable boards like that in a small box together with a note asking to confirm your grade. I'm going to do that with some stuff next time I ship a box in. I haven't had anything up or down graded yet so I don't know how that process works.
PostPosted: Wed May 11, 2022 8:40 am
I have several boards set aside to be graded at some point, but haven't been high priority. I prefer to have them sorted and ready top be processed, but if I could instead send them in a bag to be graded and save a bunch of time, I would be fine having them graded upon arrival. Saves me time and effort.
C.
PostPosted: Wed May 11, 2022 3:48 pm
I started to write a reply last night but felt I was getting a bit of a rant going so I stopped myself. Hopefully after a little time to organize my thoughts it's less ranty... maybe...
I don't send in much that hadn't been sorted already. I think the one thing I have were partially processed or mutilated CPUs/ICs that someone else got ahold of before me. I didn't get paid for them due to their condition but it was only a few ounces out of probably a couple hundred pounds or so of CPUs I've ever sent in.
For low grade, midgrade, peripheral, telco, motherboards and similar, if I'm not sure I inevitably throw it into the lower grade of what I'm thinking it might go as. If the board is particularly unique compared to anything I've seen before that's when I look into posting it here. None of those grades ever get sent to boardsort unsorted or separate from my quoted material. But that's just me. I can't speak for boardsort and having limited experience with sending unquoted material in I can't recommend that, I would recommend emailing Chris (boardsort) first if you're thinking about it. I do believe I have seen suggestions of grading the material on the lower end of what you think but then separating it from everything else so they can check it. For instance, sending a box of high peripheral but maybe a few boards were bordering low telco. Make sure everything is securely separated and make it easy for the boardsort employee to recognize those potential upgrades.
PostPosted: Thu May 12, 2022 8:41 am
Noted. It's not that I have a lot of these odd boards, they have just not been a priority for me and that batch has a bunch in it now. It would be several posts on this forum and I am trying to limit the boards on any one post...so it would take some time. All about priorities and efficient use of time. No Worries, I will get to the eventually.
C.
PostPosted: Thu May 12, 2022 11:45 am
That's what I was trying to say, but you explained it much better. I am planning on putting several items in a box that are high grade periph and then a separate bag in the same box with items that will be weighed and sorted with the HGP but might be upgraded to something else. I think if all similar boards for multiple machines are together it makes sorting much easier.
