It is currently Wed Aug 05, 2026 8:07 pm
 Post subject: Gotta minute?
PostPosted: Thu Jun 09, 2022 7:39 pm
Just a few looking for an opinion on
 Post subject: Re: Gotta minute?
PostPosted: Thu Jun 09, 2022 10:57 pm
High telecom, remove steel. If riveted on, drill out rivets and remove.
High telecom, remove wire and sister board
Backplane, possibly high telecom.
Low telecom, see above about steel.
PostPosted: Fri Jun 10, 2022 12:15 pm
Last board. i read some where in the forum that you can cut the boards this is a candidate for cutting the transistors area and end up with a high telecom ??
PostPosted: Fri Jun 10, 2022 2:45 pm
I wouldn't risk it on this one, you have a higher grade board then, but it weighs less. Wait to see if anyone else responds. You could also email Lost about it.
PostPosted: Sun Jun 12, 2022 7:42 pm
Last board that brace is likely aluminum; looks similar to a board I've had. I wouldn't recommend trimming anything either but do pull the brace. I agree it's at least low telco but may even clear high between the chips and gold fingers.
