It is currently Fri Oct 30, 2026 9:02 pm
PostPosted: Mon Jul 25, 2022 12:40 pm
Hi,
I noticed the CMOS (coin/cell) batteries need to be removed from motherboards prior to dropping off. Do they also need removed from laptops being sent in as partial?
I've been pulling the HDD, RAM, and regular Li-ion batteries, but wasn't sure if I need to open them up far enough to pull those.
Thanks,
Uriah
PostPosted: Mon Jul 25, 2022 3:18 pm
If you can easily access them, they should be removed.
If not, then leave them be. Nobody expects you to take apart a laptop to remove a battery then put it back together. ;)
PostPosted: Tue Jul 26, 2022 11:44 am
Thank you kindly.
