It is currently Wed Aug 05, 2026 3:14 pm
PostPosted: Sun Jul 24, 2022 12:36 am
what classification do these two boards fall under? one is a line card and the other is a supervisor card. Both are from a Cisco Catalyst 4500 Network Switch
Here are some closrr looks at the board as well as beneath the heat sinks. Looks like a lot of gold to me.
PostPosted: Mon Jul 25, 2022 1:52 pm
Removing all of the heat sinks, usually just a twist with pliers will do, will help grading.
Also that looks like a ram card on the second board(IMG_2396), should come out by pulling from the socket but may have a latch there holding it in place by it's two small round cutouts. Ram cards have their own categories depending on gold or silver fingered connectors.
As far as grades for the two main boards, I'm not confident enough to classify things too much so hopefully someone else can respond soon.
PostPosted: Mon Aug 01, 2022 1:03 pm
The one with the 6 large heatsinks is high peripheral, and the one with a lot of chips is at least low telecom, but could be high telecom.
Jim, could you post a picture of the entire board that is covered with chips after the above stated things have been removed? Thanks.
PostPosted: Mon Aug 01, 2022 6:23 pm
PostPosted: Tue Aug 02, 2022 12:04 am
High peripheral (one with 6 large chips) and high telecom (one with many chips).
PostPosted: Tue Aug 02, 2022 12:11 pm
Battery!
Pull that off.
PostPosted: Tue Aug 02, 2022 12:58 pm
Bonus *s for marked141
Batteries
