PostPosted: Tue Aug 02, 2022 1:07 pm
Hi,
Motor w/ double sided green boards attached. Would these go as mid grade? Even if can't get metal bracket off? (Possible surely somehow to get bracket off, but not easy even after screws removed. (on left in pic))
I'm guessing the 1 sided brown board ones I would just break motor off for that buck, and board in the low bucket.
Thanks.
PostPosted: Fri Aug 05, 2022 12:02 pm
I wonder if the three holes in the motor cover line up with three screws inside the motor holding it to the board? Seems like a lot of work for such a tiny board. Without the motor the board itself might get Peripheral Low Grade.
PostPosted: Fri Aug 05, 2022 12:45 pm
Low grade, or motors at a local yard. Not worth removing because the board weighs nothing on its own.
