 Post subject: id help please
PostPosted: Tue Aug 16, 2022 7:46 pm
pic 1 has a removable p4 no metal cpu. the new video says a p4 motherboard has a perfectly square center. this one is not square. any thoughts.
pic 3 seems to be ram with dipswitches. i havent seen this before. is this still ram or is it something else.
thanks in advance.
File comment: 3. ram ??
File comment: 2. nothing on back (backplane??)
File comment: cpu from no1
File comment: 1 front and back
 Post subject: Re: id help please
PostPosted: Tue Aug 16, 2022 11:40 pm
3) I lean toward Gold Fingered RAM. May be unique enough to go somewhere else but I don't know.
2) I don't think it would be able to go backplane. Either high peripheral or low telco; I'm leaning low telco myself.
1) Bally makes slot machines and other gambling machines...
Oh, hey! Look, someone posted some gambling MBs here before.
So looks like the RAM is specifically made for those boards. And Lostinlodos said High Telco on those so good chance 3 will get high telco but I can't guarantee that.
PostPosted: Fri Aug 19, 2022 8:20 am
The DIP switch on the ram stick will have to be pulled then it will be considered Gold Fingered RAM. With the switch on there it will be Shielded. I recognize that sounds like a drastic drop but the switch will need to be removed by us at some point before we do what we do which takes time to weed them out and clean them hence the lower rate.
The CPU is a Green Fiber No Metal.
With respect to the board, if this were a PC motherboard, that socket would be a P4 Green (I know it is not perfectly square but close). However both of these game boards are Peripheral High.
The post referencing other gambling boards as High Telco were correct. If you look at those boards they are better than these.
Hope that helps.
