It is currently Fri Oct 02, 2026 4:52 am
PostPosted: Fri Oct 07, 2022 2:05 pm
I threw these in with low grade telecom, can anyone let me know if I'm wildly off base (and maybe why, if you have the time and inclination, so I can learn)? Not a lot going on on the back sides of these boards so maybe they're high peripheral instead? Thanks!
PostPosted: Mon Oct 10, 2022 11:02 am
The high Peripheral boards in this collection are 1,2 and 5. The remaining are Low Peripheral.
PostPosted: Mon Oct 10, 2022 1:38 pm
Thanks Chris!
PostPosted: Tue Oct 11, 2022 4:20 pm
It's always great to get a solid answer from the Boardsort guru! With that said I am wondering why 8 and 3 don't fall into the high grade. They seem to have multiple ICs on them and that is what I use to determine high vs low peripheral.
PostPosted: Tue Oct 11, 2022 10:28 pm
The screw terminators on 3 & 8 are going to add a lot of weight so that makes sense.
PostPosted: Fri Oct 21, 2022 1:16 am
Huh. If I removed the terminators would that push them into high?
