It is currently Thu Aug 27, 2026 9:50 pm
 Post subject: please grade
PostPosted: Fri Sep 04, 2015 8:27 am
There seems to be a lot of gold components on this board. What would be the grade as is?
 Post subject: Re: please grade
PostPosted: Fri Sep 04, 2015 11:30 am
It appears as if the contents are similar to clean cell phone boards. I would consider anywhere between telecom and clean cell phone board grade.
PostPosted: Fri Sep 04, 2015 12:17 pm
It's atleast gold cap board with the 1010 alpha there. Possible for air card (special quote) or cell grade.
PostPosted: Fri Sep 04, 2015 12:20 pm
Only if you have experience
IF you can cleanly and completely remove the 1010a it is 8086gold cap gold pin. And still a high value board.
I'd use a desoldering wand. Not a heat gun.
The other gold caps are not ICs and shouldn't be removed.
