PostPosted: Wed Nov 16, 2022 7:49 pm
Boards 1,2 and 3.
Boards 2 and 3 have a gold cpu I can remove without breaking...what will these 3 be classified as? Thank you
PostPosted: Wed Nov 16, 2022 9:19 pm
1. Gold finger card, barely. if you want to be sure put some of the 20 legged ic chips back in their sockets.
2. Gold capped chip board, do not remove the chip because it is soldered. just because you can remove the chip does not mean you should. High peripheral if you remove the chip.
3. If the chips are SOCKETED then you may remove the three ceramic chips. If not, same deal as #2; gold cap chip board, high peripheral if chips unsoldered.
PostPosted: Wed Nov 16, 2022 9:21 pm
Thanks so much!
