PostPosted: Tue Jan 03, 2023 1:38 pm
Howdy, can anyone tell me if there's anything special to these boards and wires with what I think is graphite wrapped around them?
Is it indeed graphite, and what's it for?
Would boardsort want these items as-is, or would they be better with the graphite(?) removed?
Any insight would be appreciated, thanks.
PostPosted: Tue Jan 03, 2023 1:58 pm
Those are Ferrite bead noise suppressors. I've never seen one attached to a board.
https://en.wikipedia.org/wiki/Ferrite_bead
Probably worth $0.03/lb.
PostPosted: Tue Jan 03, 2023 2:08 pm
Huh, interesting! Thanks very much.
PostPosted: Wed Jan 04, 2023 12:28 am
Assuming the cable ends have gold plated pins you could cuts the ends off the wire for gold plated connector ends, slide the ferrite off for steel and throw the wire in your insulated wire pile.
