PostPosted: Fri Jan 06, 2023 2:29 am
Hello all, So I see the hard drive boards has been split into two categories (low and high grade, listed as sata and ide respectively) and while I understand this split in terms of more modern very small sata hard drive boards. What about boards that are nearly identical, I dont understand why the top board pictured would be half the price of the lower board? Could someone please explain this or point out something i am missing in terms of how to group these boards. Thank you!!!
PostPosted: Mon Jan 09, 2023 5:36 pm
I remember a post that discussed the technical details of the difference in construction of the boards, but can't find it now. I'm not sure if you read this post but it does give some info on why SATA boards are lower value.
viewtopic.php?f=12&t=21549&p=43051&hilit=non+sata+hard+drive+board#p43051
Quote:
As technology and miniaturization progresses, manufacturing processes evolve requiring fewer components and lower cost materials.
Hard drive boards have not been immune to this progression. The increasing number of lower grade modernized SATA hard drive boards has forced the e-scrap industry to make some difficult decisions. These newer SATA boards return nearly half the amount in terms of recoverable materials than their older IDE and SCSI cousins.
As the ratio of SATA drives increases the overall value of the entire load decreases. Where there used to be a 3 to 1 ratio of IDE/SCSI -vs- SATA, the ratio has since flipped.
Maybe what you have here is an later style IDE and a early style SATA that are very similar.
