PostPosted: Mon Jan 30, 2023 11:31 pm
Please help. And thank you..
File comment: Dell small socket mpga 478b. Has gold finger and connectors. With metal plate on underside I removed...
File comment: Double gold tab tv components. High periph?
File comment: Tv components.
File comment: Low grade telecom? Or high grade periph? Old credit cardboard
PostPosted: Wed Feb 01, 2023 11:03 am
The first board is a small socket green motherboard. If I were you I would trim the fingers off this board. It won't effect the value either way. Meaning it's not worth more with the fingers and not worth less without them. Board 2, from what I can see, yes high grade periph. Board 3 (TV components) again, from what I can see, it would be high grade periph. The last board, and this is where I really don't like how you photographed these, I would consider low grade telco. The problem is you need to photograph the whole board, front and back, in good lighting so we can see what you really have. Bad pics get you a bad assessment. Good luck.
Mal
PostPosted: Thu Feb 09, 2023 2:56 pm
The last one looks like one from a Verifone Tranz terminal, I've taken apart a few of those but I'm not sure if they would be high perhipheral or low telecom. I don't have any photos with me but this is how the whole board would look like (there's not really much that's missing from OP's photo) https://www.vintagevibe.co.nz/single-bo ... tranz-330/
