It is currently Wed Sep 23, 2026 3:35 am
PostPosted: Mon Feb 27, 2023 6:51 pm
Help grading thanks. Just as a guess . 1 unknown 2 and 3 clean gold finger card 4 high peripheral 5 high peripheral maybe not sure with two capacitor and 6 high peripheral or low teleco.
PostPosted: Tue Feb 28, 2023 8:03 am
As a forewarning, I can't say I'm always correct on these but some help is better than none, right? Last run I made they upgraded a board with a grade that I didn't know existed but otherwise didn't alter my grades. I often go through these posts and if there are replies I'll grade them in my head and then check the response to compare how my grades stand up.
Anyway,
1 - Wondering what is under the metal under that barcode and whether it's a shield or a component, as it stands looks like it would be midgrade
2 and 3 - Gold finger card clean
4 and 5 - Midgrade
6 - Peripheral High
PostPosted: Tue Feb 28, 2023 12:40 pm
On 1 it I believe is the rf transmission component these ones tend to have a gold band at the bottom but not always. I'll try to remove the cap and see. Also on 4 and 5 all the connections are gold pin if that makes any difference. I forgot to add that.
PostPosted: Tue Feb 28, 2023 12:44 pm
This one does have the gold band hard to see in pic but is at the end of the screw driver. Also hard to remove the soldered shield.
