It is currently Sat Sep 26, 2026 10:19 am
PostPosted: Sun Apr 16, 2023 12:48 pm
This is from a Cisco router. Will it grade as high grade telecom or something else? Thanks
PostPosted: Mon Apr 17, 2023 5:57 pm
I'd call it high peripheral, based on Boardsort's example in their price sheet.
PostPosted: Mon Apr 17, 2023 9:43 pm
The difference I’m seeing is the board I have has two gold corner tabs and no transformer which I would think would improve the grading.
PostPosted: Tue Apr 18, 2023 1:07 pm
You are correct, but there are some heavy modules on either side of the board. I wish these type of boards were high grade telcom consistently because I have several to classify. It might bump up into low grade telcom.
High Grade Telecom is for very high grade boards, usually having a lot of IC chips, gold pin connectors, etc. and little junk weight from large capacitors, steel, unpopulated areas or not populated with valuable materials.
https://boardsort.com/telecom.html
Here's another great post on the differences between hi/low grade telcom.
viewtopic.php?f=4&t=20773&hilit=+layers
PostPosted: Tue Apr 18, 2023 10:58 pm
Will removing some of the heavier capacitors, etc potentially allow boards to upgrade? Or, trimming dead weight portions off of boards that are chip heavy on one end and not the other?
PostPosted: Wed Apr 19, 2023 7:47 am
Peripheral grade.
Unless you can conjure a denser chip population, removing the junky stuff won't help you.
PostPosted: Wed Apr 19, 2023 11:55 pm
Removing stuff could help but then you have to recycle the "stuff" separately. Usually this is to your detriment but not always.
For instance:
Trimming gold fingers off RAM sounds like a good idea but the weight of the fingers times that nice looking $40/lb plus the weight of the trimmed RAM times $9.25/lb is not going to pay as well as leaving it alone for the total weight times $23/lb.
I buy some of my stuff from a guy who decided to do what I described above and it cost him. Don't recall how much but it did.
On the other hand removing the stuff that is recommended for removal keeps you from having a downgrade. Oversized heatsinks, fans, steel and batteries.
PostPosted: Thu Apr 20, 2023 8:22 am
Here's what the board would look like after (digitally) trimming the extra weight off.
PostPosted: Thu Apr 20, 2023 9:09 pm
If I were to remove anything it would only be aluminum capacitors and transformers. Other than batteries. I figure everything else would have gold connectors. But if it doesn’t upgrade then all I’m doing is losing weight so I won’t do that either. Thanks for all the help.
