PostPosted: Fri May 19, 2023 3:27 pm
Hello.
I have been removing heatsinks from Shielded Gold-fingered RAM using a heat gun. First of all, what's the optimal temperature setting? (My heat gun ranges from 125 F to 1300 F.) Some heatsinks seem to require higher temperatures than others. Is there a temperature that will damage the RAM to where it's no longer acceptable as Gold-fingered RAM once the heatsink is removed?
Also, many of the sticks still have some glue on the ICs or across the blank side. Is it still acceptable as Gold-fingered RAM? Or will I have to manually remove this glue? Photo attached.
File comment: Gold-fingered RAM sticks with heatsinks removed.
PostPosted: Fri May 19, 2023 3:43 pm
Use a small standard screwdriver. You will get the same outcome. No electricity needed!
Glue is fine, regardless of the amount of residue leftover from the shielding removal process.
PostPosted: Fri May 19, 2023 4:46 pm
Screw driver works better for most ram. Once you get a corner loose just follow the glue around the edge like a tuff potato skin.
Stubborn ones: 750-ish at 6 inches distance
Any hotter you risk reflow of the tin. That’s really bad on modern ram where pure surface mounting is used with no anchor pins.
PostPosted: Mon May 29, 2023 9:45 pm
I tend to set ram against my small electric room heater and let it sit awhile. Usually thats more than enough to pop off the heatsinks.
