It is currently Sun Oct 04, 2026 6:28 pm
 Post subject: Need Help Grading Boards
PostPosted: Sat Jul 08, 2023 10:24 pm
Please grade these Boards. Thanks for your help!
PostPosted: Sun Jul 16, 2023 2:42 pm
Remove the brackets and separate the boards on all of them.
A22. Yes all connector ends
A21. Top board is high telecom. Can't see bottom
A20. Large socket motherboard
A19. Both high peripheral
A18. High telecom
A17. High telecom
A16. Midgrade
A15, A14, A13, A12, A11 High telecom
A10. Low peripheral
A9, A8 High telecom
A7. Gold cap chip board
A6. High telecom
A5. Not sure, separate the boards
A4. High peripheral
A3. Low peripheral
A2. High telecom
A1. High peripheral
PostPosted: Mon Jul 17, 2023 7:17 pm
Thank You. What is the best way to Remove Brackets without damaging the boards, They are riveted on.
PostPosted: Mon Jul 24, 2023 9:23 am
I am going to give you a couple of good pointers here. 1. Separate all of your boards. Take the screws out and separate them. 2. I use a Dremel with a cutoff wheel on it to remove those brackets (please use a mask while doing this). Cut about halfway through and then you can snap them off. 3. Don't post so many boards to one thread. There is lots of room here and it makes it easier on us to go through 5 smaller threads than it is to go through 1 really big thread. Thank you.
