PostPosted: Fri Nov 03, 2023 5:19 pm
So yes as title mentions I need some clarification on what grade would the boards coming from modem/routers be. I have roughly 40 pounds of these type that all look the same and have same components on all of them . Gold plated pins where a Ethernet cable would plug in , gold corner chips, as well as gold plated oscillators on all of them . I’ve heard many different things on what grade they would be , but I would like some definitive answers to this . Thanks
PostPosted: Fri Nov 03, 2023 10:00 pm
There are general rules that you can follow on common boards but even with a general rule you'll come across things that don't fit.
These will most likely be high peripheral. I see there are some boards attached to at least a couple boards, they may or may not have more value on their own. Remember to remove wires and metal shields. I see on one board you removed what I call the metal fence that is soldered to the board and would have a lid on it. Normally you can leave that but sometimes to make the higher grade it should be removed.
Feel free to lay the boards out for a pic so we can see them clearly and let you know if we see something that doesn't fit high peripheral.
PostPosted: Sun Nov 05, 2023 9:29 pm
Here’s some close up pictures as you requested to be more specific in the way of modem/router boards.if there’s any thing special about these boards pictured let me know so I have a better idea of what to pull from this big bin of modem/routers I have . And if you could please explain why it would fall into a different class if at all . Thank you!
