It is currently Wed Sep 30, 2026 12:11 am
PostPosted: Tue Nov 14, 2023 10:58 pm
Here is an additional pic of boards that I need identifying and grading. Thanks
PostPosted: Wed Nov 15, 2023 7:06 pm
This looks like it could be a High Grade Telcom board. Is there anything on the back? Is there anything under those metal squares on the right side?
PostPosted: Thu Nov 16, 2023 3:12 pm
I will check. For sure nothing on the flip side. I don't believe so under the metal, there were heat sinks and round metal diode type components. But I will check again. Thanks
PostPosted: Mon Nov 20, 2023 10:23 pm
Remove the fuse
PostPosted: Wed Nov 22, 2023 4:36 pm
I will remove the fuse and thanks for the input. All info is well appreciated.
