It is currently Wed Jul 29, 2026 6:29 am
Post new topic This topic is locked, you cannot edit posts or make further replies.  [ 26 posts ]  Go to page Previous  1, 2, 3  Next
 Post subject: Re: What's inside it?
PostPosted: Thu Sep 24, 2015 3:15 am
Oh sweetness!!!
In 1998 (ish) Sega began to look at peripheral partner deals to test out companies for the upcoming universe computer gaming system
One of those was Ko. A one miss wonder who created the gpicu
Like the Saturn and dreamcast the icu was /way/ ahead of its time. Every cart had a front facing camera.
Here's the rom. A Massive dlp that takes up most of the board.
This is from an unfortunately doa prototype (on eBay if anyone wants it) Of Michi e Go
The entire flipside is a 2x1 inch dlp
PostPosted: Thu Sep 24, 2015 3:19 am
Ah. More retro.
The coleco was quite the system in it's time.
The two on the left telco since the board is fully flashed and the ics are reprogrammed 6600 blanks (64c09 knockoffs) with virtual switches.
Centre is at least gold finger
PostPosted: Thu Sep 24, 2015 3:24 am
The Atari 7800. All officially licensed chip boards will be telco.
PostPosted: Thu Oct 01, 2015 12:58 pm
Total waste of time.
Digital antenna.
Copper brass and plastic. Plus cast iron.
Throw them whole into your cbm bin.
Sadly the most value is in the cast iorn carbionite bars.
[Edit] i missed the decimal adding value is 40-60¢
Take the 25-50¢ s cbm. It took forever to get the brass apart since the screws strip instantly.
Total time apart was over 20 minutes most spent on the screws till i finally said #$&* and cut the ends off.
PostPosted: Thu Oct 01, 2015 1:05 pm
Qualcomm airphone
Nice everything inside is cell class boards.
The steel shields are all nickel plated for highspeed stainless 300 series.
And the abs is coper coated so cu recovery rate.
PostPosted: Sun Oct 04, 2015 9:25 pm
Generic rgb overhead controller.
Not great but not bad for free.
2 peripheral boards (the pad board is fully flashed on both sides but has nickel switches not silver. :(
So 25-30c
Not any trouble though so if you come across them take a 'flathead' standard screwdriver to the edge and pop it open. Better for the environment takes 10 seconds or less from complete to the photos
PostPosted: Mon Oct 12, 2015 4:59 am
ti nspire
A cell class main board
A peripheral class screen board (pain in the arse to get the screen loose)
A telco class board for the keyboard i removed the gold fingers so now peripheral.
Aluminium foil radio shield and some breakage. Not bad for 2.99.
PostPosted: Mon Oct 12, 2015 5:02 am
For some reason i think i did this already but regardless... the Texas instruments ti-80 ti-81 ti-82 calculator
So to reiterate the ti 80x and 90x family all are almost identical from a scrap perspective.
Exceptions are 83 84 and 89. All worth over scrap dead even if You ran it over with an a-4 m3 tank.
bare scrap comes in about $5
83s are all worth >$34 trade
84s >$20
84+ >$36
89 >$45
98 aka voyager aka 99 >$80 doa
PostPosted: Wed Oct 14, 2015 2:20 pm
Late 80s-94 ish
Motorola car phones.
Some high grade aluminium
All the boards are fully flashed silver or gold.
Most of this is telco class. The speaker case and shields are silver plated nickel.
Wear gloves with these. Sorry about the minimal pics on this one. I wound up covered in thermal paste. Hence... wear gloves with these. ;)
PostPosted: Fri Oct 23, 2015 12:42 am
N64. Mario Mario and Luigi Mario. (Film reference).
Or in this case the unstoppable beast Goldberg.
Once you get into it... the boards run telco.
