It is currently Thu Sep 10, 2026 6:20 pm
 Post subject: Would these be accepted?
PostPosted: Sun Dec 17, 2023 9:08 pm
New to scrapping. I have a partial pallet of switches. Two boards in each - see pics. Smaller board is very dense (heavy). I can't find an equivalent under the sample pics, but could very well be missing something obvious. Are either of these accepted? If so, what category would they grade under?
Thanks,
C
PostPosted: Mon Dec 18, 2023 12:26 am
The top is low telco
The bottom is midgrade
PostPosted: Mon Dec 18, 2023 12:38 am
Thank you.
PostPosted: Tue Dec 19, 2023 10:56 pm
One more round of classification questions.
Img 6867 - Board on top in pic is periph, but high or low grade? What about other two boards?
Img 6866 - This is very similar to the pic I posted above that came back a mid-grade. Does the gold at the edge change this or still mid-grade?
Img 6864 - Laptop WAN card on the bottom, and various other cards with gold fingers. Same classification as clean GPU's or?
Thanks in advance.
PostPosted: Wed Dec 20, 2023 12:50 am
All high peripheral
Mid grade. Cut the fingers off
The cards are gold finger card. The port extender is high peripheral.
PostPosted: Fri Dec 22, 2023 4:55 pm
Laptop docking station board. High perph?
PostPosted: Fri Dec 22, 2023 7:13 pm
Yes.
PostPosted: Thu Dec 28, 2023 12:02 am
Telco boards from switches - should I remove the black aluminum cooling blocks or do they need to be left as-is?
PostPosted: Thu Dec 28, 2023 1:21 am
The blocks and fan need to be removed.
The board is high peripheral.
PostPosted: Thu Dec 28, 2023 11:22 am
Fan and power source assembly on upper left are separate from board in these, so I am good there. Have been pulling the blocks so will continue with that. I had just got to thinking about the scavenging stuff off motherboards discussion and wanted to make sure I wasn't taking something that was going to cause a value problem.
