It is currently Sun Sep 20, 2026 8:23 pm
PostPosted: Sat Dec 30, 2023 11:18 pm
Can someone help me to identify these boards? Also, does Boardsort accept the small magnets found within printers, etc.? If so, what do you categorize them as? Thank you so much!!
PostPosted: Mon Jan 01, 2024 3:56 pm
Brown boards are low grade. You have a couple gold finger boards, remove the shields. The rest are mostly high perph.
PostPosted: Sun Jan 21, 2024 12:42 am
I'm fairly new to this stuff. What part is the shield?
PostPosted: Sun Jan 21, 2024 11:50 am
The shield is the metal box. They're on the gold finger cards, and it looks like you have one on C of the fourth picture down. With a lot of them you can just pop the top off of it with a flathead. Others you'll need to use pliers.
PostPosted: Mon May 20, 2024 9:27 pm
are the shields ALWAYS supposed to be taken off?
Regardless of whether or not they are soldered to the board?
PostPosted: Fri May 24, 2024 6:17 pm
Okay, so those A, and B, boards are no longer considered just gold finger cards anymore. They are fingered laptop wifi cards and sell for $8.00 a pound. As far as I know, the shield no longer needs to be removed.
