PostPosted: Sat Jan 27, 2024 12:48 am
I think these are all clean gold fingers but idk just a little help please.
PostPosted: Sun Jan 28, 2024 8:14 am
Bottom, yes, clean gold fingers. Top, you’ll need to trim the fingers off then the rest would probably go as connectors unless you got the pins out then it’d be gold pins.
PostPosted: Sun Jan 28, 2024 8:16 am
On closer examination, you’ll need to trim just a bit more from the fingers. The excess green pcb and some of the bits that are sticking out unless there’s gold on them. For that little bit they might not care as much but if you had a lot more they’d need to be a little closer all around.
PostPosted: Sat Mar 23, 2024 6:54 pm
Hope this isn't a stupid question. Are gold fingers from ribbon cables excepted as gold fingers?
