It is currently Thu Oct 29, 2026 4:08 pm
PostPosted: Sun Feb 04, 2024 9:08 pm
I have question on how to grade these boards they are out of Cisco Catalyst Switch. One is the main board, and the other is the devices connection. I know that I can depopulate the heat sinks.
The second question is have some SCSI hard drives and not sure if they Low or High grade boards for hard drives.
PostPosted: Mon Feb 05, 2024 12:20 am
SCSI hard drive boards are high grade. The bottom pic is most likely high teleco. I can’t say for sure on the other one.
PostPosted: Fri Feb 09, 2024 9:10 am
Old hard drive board after it is removed from the hard drive, other wise it is HHD with board.
High peripheral, remove heatsinks and steel around external connectors.
Telecom, probably low but might go high, remove heatsinks and steel around external connectors.
