PostPosted: Mon Apr 01, 2024 5:53 am
What would these be considered?
Alisha Washington
PostPosted: Tue Apr 02, 2024 12:44 am
I am not 100% certain but probably wire wrap pin board
PostPosted: Thu Apr 04, 2024 2:53 pm
I wonder what the technical difference is between "wire wrap pin board" and "pin board". I assume the amount of plating is thicker on the wire wrap, thus the scrap value being higher. They could also be plated pins, just held together with the plastic
PostPosted: Sun Apr 07, 2024 4:00 pm
From what I'm aware, wire wrap has thicker pins and therefore more gold on them.
These might be just regular pin board grade, but I thought it may be able to get wire wrap pin board grade as there's little plastic but more metal.
