PostPosted: Mon Apr 15, 2024 8:48 pm
I’m scrapping a bunch of communications equipment from the early 90’s and I have a few of these boards which were used to connect banks of external modems. How should I classify these?
Also all of the ports had these connected to them before the cable from the modem. I think they are some sort of line filter/signal booster. How should I classify them?
File comment: Back of line filter card.
File comment: Front. Some sort of line filter card that was attached to each port.
File comment: The back.
File comment: The front. 25 pin serial port ends are soldered on.
PostPosted: Sun Apr 28, 2024 10:01 am
I don't see anything that indicates backplane. A back plane must have at least two slots for cards. I think these will go as connector ends, unless there is something special in the filter chips.
