It is currently Fri Aug 28, 2026 1:21 am
 Post subject: Clean Copper Heat Sink ?
PostPosted: Sun Oct 04, 2015 10:47 pm
Hi,
Are these considered Clean Copper Heat Sink?
Thanks in advance
PostPosted: Mon Oct 05, 2015 12:12 am
the top ones will not be, but the bottom pic will if you clean the thermal paste off them.
PostPosted: Mon Oct 05, 2015 11:37 am
It is the same items. First picture is the bottom side of the copper plates.
PostPosted: Mon Oct 05, 2015 12:17 pm
very dirty... but clean.
Yes because there's no aluminium attached.
Depending on the yars you MIGHT. Have enough resen to get nickel or silver plate rate if they feel generous.
I wouldn't mail them though unless your sending much more than that.
Cu is 90-$1.20lb right now so dump them locally if you have over 1/2 lb to tip a yard scale.
PostPosted: Mon Oct 05, 2015 12:20 pm
Dirty/mixed
Vs
Clean
PostPosted: Mon Oct 05, 2015 12:43 pm
I'm trying to fill a Large Priority Mail Flat rate box.
Should I try to file down the bottom of these or can I mail them as is for Clean Copper Heat Sink at $1.70/pound?
thanks again!
PostPosted: Mon Oct 05, 2015 12:52 pm
There's no aluminium there. It's solder. You won't have a problem with clean rate.
If you do send them do so soon before copper rate in the east by them match ours in the central plains
