It is currently Sat Nov 07, 2026 5:58 pm
PostPosted: Wed May 29, 2024 10:38 pm
Can finger card have enough going on to make high teleco?
PostPosted: Fri May 31, 2024 9:12 am
Remove the bracket and the top is surely High Telecom. If you are sending only these items, send the bottom as finger card. If it's High Telecom, Chris will upgrade it for you.
If you are sending a large box of high telecom, stick the bottom one in and it probably won't set off any alarms.
PostPosted: Sun Jun 02, 2024 9:48 pm
Thank you for the post
