 Post subject: This one?
PostPosted: Sat Sep 21, 2024 5:22 pm
What do I do with socketed chips? What grade for the board?
 Post subject: Re: This one?
PostPosted: Sun Sep 22, 2024 3:36 am
Those chips all appear to be soldered so should not be removed.
PostPosted: Mon Sep 23, 2024 11:44 am
Looks like there are 6 small socketed chips on there. Probably not enough to worry about. The board is high grade telcom @ $6.60/lb and the chips are $8.50/lb. Unless you have several boards it won't make a big difference by removing and separating the ICs
PostPosted: Sun Oct 20, 2024 2:31 am
Unless you're collecting ICs AT ALL, do not remove the socketed ICs.
If you have a collection of ICs and have been saving them to sell, pull them off; the board can still go as High tele.
Cut the gold fingers off the ribbon cable and put in gold fingers
PostPosted: Mon Oct 21, 2024 3:40 pm
Not to derail the thread but, I did not know the gold fingers on ribbon cables count as gold fingers.
PostPosted: Sun Nov 24, 2024 8:18 pm
Me either. I figured I would eventually ask.
