It is currently Mon Oct 26, 2026 10:16 pm
 Post subject: Worth anything?
PostPosted: Sat Sep 21, 2024 8:13 pm
This looked like a lot went into it so I grabbed. 1ˢᵗ time looking at it. Each blue disc looks the same both sides. Each has a white disc with four contacts that sits on top. The post is brass maybe.
 Post subject: Re: Worth anything?
PostPosted: Sat Sep 21, 2024 8:23 pm
Could be silver connectors and solder but you’d need to check it yourself.
PostPosted: Mon Sep 23, 2024 11:33 am
What kind of system did that come from? Looks like a lot of options on that switch!
PostPosted: Thu Oct 10, 2024 11:07 am
I don't know specifically. The switch is bigger than it looks. I thought I had included an image of the panel to help id. The steel has that much corrosion but the switch was perfect. There are 2 more discs that aren't being used.
PostPosted: Thu Oct 10, 2024 2:00 pm
Looks like a 4:1 I/O serial box. Interesting there’s two extra switches. Means the manufacturer made different boxes but used the same parts.
PostPosted: Thu Oct 10, 2024 2:18 pm
So, like an old skool KVM with no M! :)
PostPosted: Thu Oct 10, 2024 2:40 pm
Yes, and no.
Based on the little I can gather from the photos.
I believe I count 15 pins.
I’d guess a terminal switch off hand. Telnet or VoT?
Could also be an 8 bit keyboard and mouse. That din looks like mini XT.
Could be industrial. Serial and error correction.
Or 20-bit vax
Or any number of things. And in later days, whatever the user decided to do with it.
You’re probably right though, keyboard and mouse. Prior to the Aptiva era, d-sub and din connectors were for mouse and keyboard on many computers
PostPosted: Sun Oct 13, 2024 12:28 pm
To me it looked like audio video. Those look like vga plugs and those do look like mouse/keyboard but they also look like audio plugs. I thought mouse or keyboard and monitor but that setup wouldn't make much sense. Why would it be switched that way. I also can't figure why to switch between monitors and audio signals. This came from a city gov. along with some office phones and other junk.
PostPosted: Sun Oct 13, 2024 1:48 pm
Found it!!!
BKL had it.
It’s a splitter for audio and video.
A monitor splitter.
5 pin audio
And 15 pin VGA.
