Again would like to sort them for you to have the easiest time to deal with and not be irritating:
Have a bunch of 1 off boards-
Wire wrap, some RF connectors (soldered), ceramic PCB populated/gold, broken ceramic unpopulated PCB
I see wire wrap boards are listed- do I just break off the rest of the pcb that isn't wrap/cut the wires? Suggestions welcome.
Ceramic IC chips, some gold topped, some epoxy covered, tin covered gold (I think), gold pins. Not a lot of them- all there is here.
Bare, unpopulated, large gold ground plane PCBs. Very thick copper pours in them (from the heft).
A small handful of unused RF/Coax connectors- 'gold pin' ?
Lastly, about 11lbs of pins that have tin/gold mix, and maybe 3lbs of purely gold plated pins- all go to pin category (I won't mix the bags obviously)
Thank you in advance. This is 'holiday money' since I got laid off and I don't wish to make a mistake.
