It is currently Mon Sep 21, 2026 5:01 am
PostPosted: Sun Sep 15, 2024 11:12 pm
Hello all,
I got a bunch of Cisco VoIP phones, and upon disassembling one of them, this is what i got. How can that board be classified? and, can Boardsort take the smallest one, that has the crystal screen?
Thanks!
PostPosted: Sat Oct 19, 2024 5:24 pm
These boards will almost always (as long as you remove the junk, i.e. metal, batteries, ect.) be graded as high grade peripheral.
PostPosted: Wed Nov 13, 2024 11:48 pm
Did you ever get an answer on whether the small display has any value? (I assume not but I'm curious.)
PostPosted: Fri Nov 15, 2024 10:45 am
I've done these before and you would have to remove the board from the screen and plastic backing as well. There's not much to the board so I assume it's low peripheral at best once cleaned.
They use a sticky double sided tape to hold it together if I recall so takes a bit of flexing of the plastic while holding the board down then that will expose the screen better to remove it.
PostPosted: Fri Nov 15, 2024 2:59 pm
With a BGA gold corner, it’s high peripheral
PostPosted: Sun Nov 17, 2024 3:00 am
It’s high peripheral
I’ve sent many hundreds of these if not thousands
