I'd probably clip the gold fingers myself and put both of those in peripheral high grade or maybe low grade telecom.. If you cleaned them up(remove the metal or plastic face plate/etc.) you might get the more populated ones with less junk on them up to High Grade Telecom but I'd expect you'd want to leave the gold fingers if you were trying for that...
Just my 2c..
Edit: You'll probably have to clean them up by removing the face plates regardless of the grade you are seeking to sell at, the more junk you can remove the better they will grade. Just generally speaking.
