 Post subject: Identification help
PostPosted: Sun Jun 08, 2025 12:47 pm
I have identified the mother boards a P4 small socket, and just wanted to verify. All the others i am just not sure.
The board next to the mother board with the 5 Pin connectors has gold plated pins so is it worth sending like this or break down to connector level? or even pin level?
The very small board looks like 3 ICs (one on front, 2 on back). Microscrap for the ICs or send as is?
Thank you in advance.
 Post subject: Re: Identification help
PostPosted: Fri Jun 20, 2025 2:46 pm
This is how I'd sort them. I'm not always right, but have been doing this for a living for quite a while.
If these are single boards mixed in with a larger shipment of each category, you shouldn't get any pushback. If though you had a large quantity of each of these specific boards, it would make sense verify with whomever is buying them from you.
