It is currently Sat Oct 31, 2026 2:58 am
 Post subject: Power Adapter
PostPosted: Wed Jul 09, 2025 10:24 pm
Are only the fat power adapter's accepted? Or are regular plugs accepted as well?
Thanks
 Post subject: Re: Power Adapter
PostPosted: Fri Jul 11, 2025 3:12 pm
Any power adapter should fall into that category, the picture is just an example
PostPosted: Mon Jul 14, 2025 12:11 pm
These - Power Supply With Wire: https://boardsort.com/images/codes/4006.jpg
And these - Power Adapters No Wire: https://boardsort.com/images/codes/4010.jpg
PostPosted: Mon Jul 14, 2025 8:35 pm
So a normal power adapter is not accepted. Just the bigger ones with transformers?
PostPosted: Mon Jul 14, 2025 8:45 pm
You’re best posting a picture: we can only guess what you have
PostPosted: Tue Jul 15, 2025 12:17 pm
Is this what you are calling a normal power adapter? If so it's just called a plug (or a NEMA 5-15 plug)
PostPosted: Tue Jul 15, 2025 4:36 pm
and that would go as mixed wire.
PostPosted: Tue Jul 15, 2025 6:38 pm
I have to cut those ends off wire at my local yard or they downgrade the wire to .30/lb. :(
PostPosted: Tue Jul 15, 2025 7:09 pm
Wow. My yard downgrades if I cut them off. Lmao
