PostPosted: Thu Jul 17, 2025 8:31 pm
Got about 1 to 2 hundred of these wireless acces points in a pickup today. They have two stacked boards inside. Playing with Oscar showing it both sides of each board its telling me high telecom or peripheral on the main board and mid grade on the daughter. What are your guys thoughts? If I cleaned off the two toroids and the transformer on the daughter would it make low peripheral? And what would the gold tips on the antenna go as?
Second I opened up one of the small cisco switches in the load. Getting low telecom...if I cleaned off the transformers would it make high telecom? It's loaded with gold pins
File comment: Cisco switch front
File comment: Gold plated antenna ends
File comment: Back of daughter
File comment: Front of daughter
File comment: Back of main board
File comment: Front of main board
PostPosted: Fri Jul 18, 2025 1:44 pm
The access point board I would say peripheral high. Switch board telecome high. The daughter card I put those in peripheral high, but I honestly dont know where they actually end up in sorting. I would probably for time leave stack and just clean up front of main board and get peripheral high.
