It is currently Mon Aug 03, 2026 1:05 pm
 Post subject: Are these $5 a pound?
PostPosted: Wed Aug 13, 2025 4:18 pm
I have about 7lb of the male pins and about 4lb of the female pins. They are not all the same series but of similar size, mostly 20awg. Most of these pins are for MS3122 series connectors.
PostPosted: Wed Aug 13, 2025 5:22 pm
They are indeed categorized as gold plated pins, current rate at $5/lb.
If they are all exactly the same pins you might request a scan with the gun so they can determine the actual gold content and possibly give a better payout
PostPosted: Wed Aug 13, 2025 6:10 pm
Are the female pins gold plated on the inside?
PostPosted: Wed Aug 13, 2025 9:27 pm
Good question. I believe some parts inside are gold plated. I will check it has been awhile since I had one apart.
PostPosted: Thu Aug 14, 2025 11:59 am
Well inside the chrome barrel are gold plated contact fingers. Seeing as these are apparently $5 per pound they are not worth shipping to our host. I will look for someplace in Northern VA.
