It is currently Wed Jul 29, 2026 9:57 pm
 Post subject: Help please
PostPosted: Mon Sep 01, 2025 12:55 pm
 Post subject: Re: Help please
PostPosted: Mon Sep 01, 2025 1:50 pm
Gonna need to disassemble it. Could be some wire wrap pin boards there, though the population seems a little low. If the wires aren't pin to pin trim the wires off. Depending on what it is the wires may be more than just insulated copper.
PostPosted: Mon Sep 01, 2025 8:06 pm
Is that what I think it is?
A test jig from an automatic board tester. Zhentel??
Do you got the whole machine also. Or just a bunch of jigs?
Each jig was custom made to a particular PCB you wanted to test.
Every pin is spring loaded. Separate the metal from the gold. You got some nice gold pins.
PostPosted: Mon Sep 01, 2025 9:49 pm
Pulling the pins may or may not be the best idea, I still recommend disassembling first then you can get better pictures of each board, front and back if there's population on each.
PostPosted: Tue Sep 02, 2025 3:23 pm
Thanks I've got probably 7 of the PCB test jigs, apparently they were used by an old payphone company. Didn't know if they were worth anything. Thanks again
