 Post subject: Quad-core server?
PostPosted: Wed Sep 10, 2025 8:27 pm
Picked up a bunch of server blades computers, and other miscellaneous today. Sampling it and wow! Every piece of hardware has every ram slot and finger card slot filled. So far the computers have a motherboard that looks like an am/fm but it just socket 939 on it with AMD Athalon 64 ×2 cpu. Would it still class as am/fm motherboard and green Fibre with metal?
 Post subject: Re: Quad-core server?
PostPosted: Thu Sep 11, 2025 9:09 pm
I'm not sure on this one. Looks like AMD AM/FM Socket MB, but doesn't have AM or FM. Might be Small Socket P4 Motherboard, but doesn't fit the grade properly. Do you have just one or several?
PostPosted: Thu Sep 11, 2025 9:19 pm
Several with more possibly coming. The only references I could find on it for boardsort are really old. Considered a small socket then but before all the changes to motherboard classes. Probably need to email Chris. Ill ask about the cpu too..its solid pins across the entirety.
PostPosted: Fri Sep 12, 2025 11:09 am
The am/fm video in the grading page shows a board with a similar socket.
Definitely email Chris for clarification if you want to check if the 939 socket boards have a better known value.
PostPosted: Wed Sep 17, 2025 8:18 pm
Chris confirmed they go in the I-series and Am/Fm class
