PostPosted: Fri Sep 12, 2025 3:19 pm
Wanted to post a couple groups of nontraditional gold finger boards and try to get some clarification on a few points. Emailing Chris to see if he can chime in on this post.
Finding conflicting info in the forums on backplane with gold fingers and where they go and if the fingers can be removed if they still go in backplane.
A couple other sets of cards mostly from servers im tearing down. Some look high telecom to me and others I don't have a clue. Oscar tells me everything from high peripheral to high grade nonsata hdb to, high telecom..on the one i wouldn't think was
Pic's of front and back if anything is on it and labeled by group in the captions.
File comment: Board E one chip on the back and two sata connections. Oscar keeps trying to tell me its a high grade non-sata hdb
File comment: Board D Oscar says high telecom? Nothing on the back except a few micro IC's and small mlcc
File comment: Group C back
File comment: Group C front high telecom?
File comment: Group B back
File comment: Group B front
File comment: Group a backplane with gold fingers nothing on the backs.
PostPosted: Sun Sep 14, 2025 4:29 pm
E Gfc
D Gfc
C gfc
B gfc
A backplane
PostPosted: Mon Sep 15, 2025 4:24 pm
Technically Lostinlodos is correct with his assesment.
I will say that we will accept backplane as fingercard if:
1: They have a full set of fingers and not just a small tooth worth.
2: The expansion slots are gold plated inside.
3: No junk, metal, caps, heatsinks, no nothing. Chips and gold pins are ok obviously.
If all 3 conditions are met, you can place in gold finger card.
PostPosted: Mon Sep 15, 2025 6:49 pm
Thank you for your response Boardsort! Was finding conflicting info in previous posts with some saying backplane and others saying they were accepted as gfc when they delivered in person. Your explanation clears it up.
Although I usually don't intentionally depopulate is it acceptable to remove gold fingers from ones that won't qualify as GFC?
PostPosted: Mon Sep 15, 2025 7:03 pm
You could and would get midgrade and gold fingers.
It’s better as backplane for the payout.
