It is currently Sun Aug 02, 2026 9:13 am
PostPosted: Tue Sep 23, 2025 5:19 pm
[attachment=0]17586622914793302443632824719684.jpg[/attachment]
PostPosted: Tue Sep 23, 2025 6:11 pm
You should email Boardsort if you want to sell as is:
Me. Personally. I would diassemble.
Remove wire. You got wire.
Remove connectors. Connector category.
Those BNC connectors labled KA1 through KD3. Those are brass. I pull the gold pin. You got Gold Pins. Then I remove the plastic center. I try to remove waste. The cleaner the better. In my opinion.
After that. You got a wire wrap board.
Or remove IC's. And you got a pin board. With a few IC chips.
Having done that. Remove excess board waste.
Anyway you look at it. It's a learning experience.
Look at what you need to accomplish.
I would have time to disassemble. Since I mail my escrap. I find it to my advantage to
consolidate as much as possible. PACK my boxes as tight as possible. No empty spaces. Everything jammed in the box. I put in some copper or brass to fill in space. Helps with postage. More escrap per square inch. I never ever got close to the 75 lb limit on Priority or Ground Advantage. Yet.
That's what works for me. You got to consider your own situation.
Food for thought.
I feel your question needs to be answered by Boardsort.
I am just sharing one plan of action.
PostPosted: Tue Sep 23, 2025 7:02 pm
Once again, that's what I needed just a little guidance for a few options. It's always a breath of fresh air hearing your replays especially in today's society. TA
