PostPosted: Fri Oct 03, 2025 11:39 pm
Are all of the strips that run along the edge of flat panel tvs and displays considered high peripheral? I have a a lot that have almost nothing except for the gold along the edge.
In what category does a motherboard with a single gold cornered BGA as the cpu go.
If a board has a gold cornered BGA and no heavy junk is it safe to consider it high peripheral?
Some ribbon cables (extremely flat whit ribbons that don’t resemble wire) have gold plated ends. In what catagory would these cut ends go if accepted at all?
File comment: Poorly populated strip from lcd tv, high or low peripheral
File comment: Ribbon cable ends
File comment: Motherboard with gold cornered BGA
PostPosted: Sat Oct 04, 2025 12:55 pm
The last two images I'd put in High Peripheral, they have gold corner BGAs so better than just Integrated MB or etc.. No experience with the rest, but I don't think they buy the gold fingers from ribbon cables...
PostPosted: Sat Oct 04, 2025 2:33 pm
Thank you for taking the time to help me out
PostPosted: Sun Oct 05, 2025 7:04 pm
Personally on the LCD strips, if there's nothing on it I put those in low peripheral, if there's some IC population I will go high peripheral.
I've seen people recommend high peripheral regardless ¯\_ (ツ)_/¯
