PostPosted: Tue Oct 14, 2025 11:06 pm
Looking for some advice on what these four components would be classified as.
File comment: Image 1. This is a power brick (right term?) from an AC adapter. The wire has already been cut off.
File comment: Image 2. This is a USB dongle that you would see with a wireless mouse or keyboard. Would this fit in connector ends?
File comment: Image 3. One end of a battery cable from a laptop. I can see a gold tinge on the inside, so I was considering connector ends for this one.
File comment: Image 4. This is also a battery cable. Was also thinking connector ends considering the gold tinge.
PostPosted: Thu Oct 16, 2025 4:26 am
I only feel confident to respond to the connector ends as pictured.
Those will be in the category of Connector Ends. But. But. But. You must cut back the wires as close to the connector. The gold tint/coating puts that right into Connector Ends category. But must be prepared correctly to be accepted.
Also. That mouse dongel. Does it show gold contacts? If so. Good chance Connector Ends. Me personally. I would cut back and remove metal shielding.
Hopefully. A more experienced scrapper will chime in.
As always. You can email boardsort for an accessment.
PostPosted: Thu Oct 16, 2025 4:30 am
Oh. The power adapter. Only a more experienced E-scrapper can respond to that question.
Good luck.
As always you can email Boardsort for evaluation
