It is currently Thu Sep 10, 2026 6:15 pm
 Post subject: Landline phone board
PostPosted: Mon Oct 20, 2025 12:30 pm
How much per lb?
 Post subject: Re: Landline phone board
PostPosted: Mon Oct 20, 2025 3:09 pm
Assuming the board isn't lacquered, that looks like high peripheral to me.
PostPosted: Mon Oct 20, 2025 7:11 pm
Helps to look at the large photo. Sorry
That’s probably low peripheral
PostPosted: Mon Oct 20, 2025 10:32 pm
Pingdi wrote:
How much per lb?
That falls into the $5 HGP boards. Good board!
PostPosted: Tue Oct 21, 2025 1:36 pm
Are you serious?
Chris told me:
Midgrade board: $0.5 per pound...
PostPosted: Tue Oct 21, 2025 3:52 pm
That probably means that the board is lacquered, which downgrades the board to mid grade, which is pretty much that rate.
PostPosted: Tue Oct 21, 2025 9:08 pm
The photo is awful, which may make grading even more subjective.
Between lostinlodos and Boardsort giving you low peripheral and midgrade grades, it's likely one of those. If you can get a better picture, and of the other side if anything is there, it would be easier to verify that for you.
PostPosted: Wed Oct 22, 2025 12:43 pm
It’s a basic wide body house phone.
Before peripheral split these went as midgrade generally. But Foster, Simmons. RCA etc hade versions that were worth slightly more.
This looks like a foster 400 series base OEM
If it has the large ASIC on the back? It’ll probably be low peripheral if not it’ll likely be midgrade.
Then again, if Chris said it’s mid grade that’s what it is
