It is currently Tue Sep 22, 2026 3:02 am
PostPosted: Mon Oct 20, 2025 3:10 pm
Not sure if this board will go for Low Telecom? Old PBX system.
Thanks
PostPosted: Mon Oct 20, 2025 5:29 pm
Should remove the plastic faceplate. This would clear low Telco for sure; I'm unsure if this particular board would go high Telco or not but it might.
PostPosted: Tue Oct 28, 2025 2:40 pm
high telco is just low telco cleaned up. take off the stuff that doesn't look valuable. anything large and chunky like the red blocks there, the resistors, etc.. if it doesn't look gold, silver or a chip, it can go
PostPosted: Tue Oct 28, 2025 6:31 pm
Agree. However, that board is probably high telco even with the bits of fairly light junk.
Also see:
Viewtopic.php?f=4&t=22786
regarding some PBX boards. Some low telco can't be cleaned up.
PostPosted: Fri Oct 31, 2025 1:33 pm
Thank you.
PostPosted: Thu Nov 06, 2025 9:16 pm
Also see:
You are probably right. I still struggle with telco boards
