It is currently Mon Aug 03, 2026 6:51 am
PostPosted: Sat Oct 25, 2025 2:37 pm
Which selling category would this aluminum wire be classified under? It's stripped so it's not dirty. And. It's not a heatsink. Appreciate any help.
PostPosted: Sat Oct 25, 2025 5:19 pm
When I worked at a scrapyard that was either EC wire or ACSR. EC is fully aluminum and ACSR (Aluminum Cable Steel Reinforced) has a single steel strand in the center.
Unless you are dropping off the material in person you're probably better off taking aluminum to a local yard. But if you're gonna send it in you'll probably use the clean heatsink category on the invoice but I would double check with Chris.
