PostPosted: Wed Oct 29, 2025 8:19 pm
Hello all. I'm new to this and scrapped a few flat tvs. I numbered each pic to make it easy. Could someone tell me what category (classification) each should be? Thanks so much.
RichJ
File comment: Photo 9
File comment: Photo 8
File comment: Photo 7
File comment: Photo 6
File comment: Photo 5
File comment: Photo 4
File comment: Photo 3
File comment: Photo 2
File comment: PHOTO 1
PostPosted: Wed Oct 29, 2025 9:01 pm
Be sure you pull off any steel shields, like on 3/7/8 and aluminum heatsinks, like on 3. All of those should be able to be popped off with a flathead screwdriver. If the shields are completely soldered on you could decide to leave them on (may affect grade) or make the extra effort to remove them.
If you do that 1-3&6-9 should be good in high peripheral.
4 I lean low peripheral cause the boards themselves look lower quality but there are IC chips and presumably gold plated pins in the connectors.
5 should manage high peripheral but again the boards look lower quality. The ribbons, if there's any glass on them, should be removed as peeling those off the glass can often break the lcd panel.
PostPosted: Thu Oct 30, 2025 7:46 am
Hello marked141,
Is that the silver connector for cable? Will the RCA jacks effect the pay rate?
PostPosted: Thu Oct 30, 2025 10:55 am
The connector usually is separate from the shield (or lid), why I mentioned the potential for the shields to be soldered shut. You just want to pop the bit that's shaded orange.
You can remove the whole box if it's easier but the shield is all you need to remove. It reduces the amount of the lowest value material in the board and, while the components inside are pretty standard, allows anyone checking material to see what's there.
PostPosted: Thu Oct 30, 2025 2:37 pm
Thanks for explaining. If most of the boards are around the same size but a couple that are long and skinny, can I break them in half to fit in the box?
