It is currently Tue Sep 22, 2026 9:11 am
PostPosted: Fri Oct 31, 2025 1:11 am
Hi all,
Have a few that have stumped me.
1. Thick gold plating on both sides, but nothing else. Cut one piece and included it in the photo to try and show a bit of cross section. Board measure about 20x5 in. And weighs 240g.
2. Bin of mostly gold pins in these plastic holders. There are also some random pieces of junk like components and other metal/plastic/garbage, not much but its mixed in there. Any way to separate it besides picking it all apart? There are also some small eprom chips in there.
3. Is this blank RAM? Gold is on both sides. If so, can i leave the full strips together?
4. More blank boards with gold contacts. Not as much as #1 so wondering if it would be different.
PostPosted: Fri Oct 31, 2025 9:55 am
Have had this conversation with lost and Boardsort. For reference:
viewtopic.php?f=3&t=19554&p=35735&hilit=Blanks#p35735
viewtopic.php?f=4&t=19617&p=35966&hilit=Blanks#p35966
Basically the blanks will all be low grade unless Chris sees something to know he can get something out of them. Or if you can find someone else set up to recover the material that's there, there is potential the boards are worth more than low grade. Also, gold is much higher than it was for those conversations so possibly worth the effort currently.
The box of random stuff. I see at least ICs, capacitors, pins, gold plated pins and ribbon cables. Not sure how Boardsort would but that but it won't be much because it's mixed.
Pins are likely brass with a nickel plating, or gold plating for those. There may be some steel pins if the manufacturer could get away with that, which would be troublesome as nickel is also magnetic.
Capacitors are likely aluminum.
ICs have their own category on the price list.
Ribbon cable probably just goes into low grade insulated wire.
PostPosted: Sat Nov 01, 2025 5:45 am
Not sure how to directly reply to your comment marked141, but I hope you see this.
Thank you for taking the time to have a look and give input on my boards. What you said makes sense and i appreciate the reference to the other threads you provided.
Any thought on the RAM looking boards? Am I in Blank RAM category or no?
Full disclosure: I'm in Canada so shipping to Boardsort is not an option, so I don't want to bother Chris, I'm just seeking general guidance from the community.
Appreciate all the help.
PostPosted: Sat Nov 01, 2025 3:12 pm
Thank you mark141 for posting those threads.
Those were extremely educational. And of course all the individuals that gave worthwhile responses.
I am hesitate to even respond to our Canadian neighbor. But. I will. Hopefully I will not be referred to as "Bad Cat" or "Nefarious Whisker". In addition. My response is to the post community overall.
Good luck rickyjogging. Did you see the video of a dude starting his own boardsort in Australia. Probably time to start a "boardsort" in Canada. Hiring Chris as a consultant. Ok. Enough of that.
You wanted input. Ok.
Looking at your tote. You got some IC's. Caps. Gold header pins. And who knows what else? When you got junk. You got junk. Sort it out.
But here is my nefarious suggestion to the forum.
Plug in the soldering iron. Flatten out those IC's pins so you can "tack solder" a reasonable amount to the gold pads. Also. Caps. Gold header pins. Fill those boards up with IC's. Meet the E-scrap requirements for submission.
You may get Low Peripheral or Gold Finger Card..
Ridiculous or Serious. But it fits. Submit that PCB to a production engineer. You are gone. But that nefarious PCB. It fits the Boardsort description.
This is scrapping.
Meet the requirements it should fly.
I would not want to be Chris looking at a PCB like that. Also. Surely someone had to think about this before me.
But. Technically it works.
Thank you. My Canadian neighbor for your post.
I have several PCBs exactly like you have. Would I do what I just suggested. I doubt it.
Yet. It is something to consider.
Good luck on your adventure.
My suggestion is off the normal perspective. But. Fufill the requirements for E-scrap.
Amen and amen.
PostPosted: Sun Nov 02, 2025 9:46 pm
They aren't RAM blanks.
However, they do have gold fingers so there might be value there compared to most blanks. My knowledge on blanks is based on the input Lost and Chris in those threads, so that's all I can really point to.
PostPosted: Sun Nov 02, 2025 10:28 pm
Here are some blank RAM pictures.
At face value. It sure seems your blank boards have more gold content.
